Thread: Can composite Audio Cables be used instead of Componet Video Cables
Rick
Posted on Monday, May 12, 2003 - 07:53 pm:
Can Composite Audio Cables be used instead of Componet Video Cables. I have very good quality monster composite audio cables. Can I combine three of these individual composite cables instead of using component video cable.
I know it will work but my real question is that Is there a big difference in picture quality between the two kinds of wiring if one is not using a HDTV.
Relevant Product Info
Posted on Tuesday, May 27, 2003 - 07:19 pm:
RICK IF THE COMPOSITE ARE 75 OHM AND HIGH RESOULTION THEN IT WILL BE THE SAME AS COMPONENT VIDEO
Mike
Posted on Thursday, November 20, 2003 - 04:38 pm:
I understand the 75 ohm spec, but what is meant by "high resolution" cable?
j.j.
Posted on Tuesday, April 06, 2004 - 05:17 pm:
I've got the same question. I'm using high end Monster composite cables as component cables. I have no idea if they're 75 ohm or not but they're pretty thick and seem to work okay. Will I get a noticeable difference if I buy a $30 AR component cable?
