Bronze Member Username: WhiteblasterPost Number: 14 Registered: Oct-08 | what amp / or amps should i get? do NOT want to UNDERpower!!! looking for the perfect amount of juice for these babies, and ideas? |
New member Username: DeuslePost Number: 6 Registered: Nov-08 | 2 hifonics BXI2006D's or 4 kicker ZX1000.1's whats your electrical system look like? |
Bronze Member Username: WhiteblasterPost Number: 15 Registered: Oct-08 | nothing yet lol, im orderng everything soon, and dont know much about wattage all i have is an optima yellow capper i know ill need alt and stuff but would those 2 hifonics work? isnt that to small? would a zx2500.1 work |
Bronze Member Username: WhiteblasterPost Number: 16 Registered: Oct-08 | nvrmd scratch that i guess i can only afford 3 |
Gold Member Username: 420alldaylongPost Number: 3856 Registered: Sep-06 | 3 what? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8963 Registered: Jul-06 | If you didn't buy the subs yet don't. L7s suck. (sound quality and build quality) |
Silver Member Username: Shak180Hayward, California Usa Post Number: 171 Registered: Jul-07 | L7's look cool though |
Bronze Member Username: WhiteblasterPost Number: 18 Registered: Oct-08 | lol i just had a big argument in the sub section about which ones to buy, but these are the cheapest loudest squares i found and they dont need 4 batteries and a ton of electrical upgrades 3 2008 Kicker 15' l7's |
Gold Member Username: BonhamdPost Number: 1469 Registered: Nov-07 | thats bull shiit to properly run those subs you will need electrical upgrades did you get a car yet? why dont you just listen to us? |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1688 Registered: Mar-04 | If you're looking to run 2000w+ and run it at or near full volume once in a while you'll want, at the minimum a big /-\$$ alternator. 200A or so. One good healthy battery will suffice unless you want to run it (loud) without the engine running more than a couple minutes at a time. And I think if you ask around you'll find a LOT of people that would adamantly argue M.S.'s opinion on L7's. |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14400 Registered: Jul-05 | y does any1 really 'want\need' 4 15s ... |
Gold Member Username: BonhamdPost Number: 1470 Registered: Nov-07 | i dont think L7s are bad at all - i have owned 3 different L7 15s i am just saying that i think he can do better than L7s with his budget |
Gold Member Username: 420alldaylongPost Number: 3865 Registered: Sep-06 | I bet you would love 1 good 15" on 1000RMS. |
Platinum Member Username: InsearchofbassPost Number: 10885 Registered: Jun-04 | Perhaps a audioque hdc 15 or 18 on 1200 watts. dual 2 ohm audioque 1200d 1200 at 1 ohm for $249 http://www.audioque.com/aq/HDCSeries.htm http://www.audioque.com/aq/order.htm |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2097 Registered: May-07 | An L7 would sound fine on rap or similair music. But on rock or anything with true instruments, they sound like poo. Atlest the 15"s do... |
Bronze Member Username: WhiteblasterPost Number: 19 Registered: Oct-08 | well the rock and rapi kisten to allhit in my car, and i got two little brutus squares, and my buddys l7's beat the crap outa my sub |
New member Username: Blaze87Post Number: 2 Registered: Nov-08 | they will get loud dont get me wrong we carry them, but why not get a sub that gets loud, and still sound good on all types of music? the hifonics squares? thats not even a sub in my book, spl or sq, jmo fi-bl aq-hdc3 alpine-typer jl-w7, many more but, then, what is your budget? |
Bronze Member Username: WhiteblasterPost Number: 20 Registered: Oct-08 | ok i dont want everyone in the forum yelling at me again for this, my budget is 2k for subs and an amp, all electrical and everything seperate I am in the process of choosing an suv type vehicle, and am not decided on the honda cr - v, or jeep grand cherokee, chevy trailblazer, or some others in mind ive heard the type r's, and i mean their LOUD, but i never really felt them in the dudes car and dude you really shouildn't diss thos brutus squares, they slam pretty hard for only 120 bux a pop, they just dont hit real high or low low, but it was my first system, and those things shook every part of my 95 grand am off, and are in the process of destroying a 2002 grand prix se anyways, i keep finding and losing the site, but i have a LEGITAMATE kicker dealer that wil sell me 4 2008 kicker l7 15' subs for 900 bux w/sh i also found a legitamite site that i can get the 2008 zx 2500 for 800 bux i was wondering if that would be enough to power all four safely, an not underpower? i will have two yellow capper optima batteries, and il end uip getin a cap and alt soon after the order |
Gold Member Username: BonhamdPost Number: 1507 Registered: Nov-07 | so are you dead set on a SUV atleast? the vehicle is an important factor in choosing sub sizes due to the air space you can get some really good deals on RD Audio at the moment https://www.ecoustics.com/electronics/forum/car-audio/529468.html |
New member Username: ToyotwincamgtArroyo, Puerto Rico United States Post Number: 10 Registered: Jul-08 | brutus is a little overrated u need roford fosgate |
Bronze Member Username: WhiteblasterPost Number: 21 Registered: Oct-08 | what are you talkin about dude? i was just mentioning my 12' square HIFONCS BRUTUS SUBWOOFERS i wasnt referencing amps but yes i am dead set on an suv or extendeed truck and would the zx 2500.1 powwer um perfect or do i need more? |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1718 Registered: May-07 | the L7's would work on that power. but really need more than that for 4 -15's. I would do a minimum of 3500wrms.. maybe AQ3500, or rd 3250 @.5ohm. . Maybe you can find a used Ia40.1. RF Tpower 4k(cant believe i said that), or equivalent. Seriously.. get the AQ HDC3 15's. with 4 of em you will forget all about what coulda been with the squares. <----been there - done that- moved on |
Bronze Member Username: Beatin_down_yo_blockOkalhoma City, Oklahoma United States Post Number: 35 Registered: Apr-08 | ok check out onlinecarstereo.com, save money go with 4 kicker L7 and get 2 1500 watt Kicker amps.. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 9227 Registered: Jul-06 | Or you could not buy shitty sounding square subs |
New member Username: JoshualittleColumbus, Ohio United states Post Number: 8 Registered: Dec-08 | Bro with a budget like that I'd be looking elswhere for subs and amps, I can get you a deal on arc audio amps, hertz subs, you name it. For $2000 you can have a hell of a system. Why not 2 arc audio ks 1000.1's and 4 jl audio 12 w6's, well below your budget, I can get the amps for about $400 a piece, woofersetc.com wants $550 for them and dealer cost stereo, just go to caraudio.com and scroll down and you'll see it. They only want $279 shipped each for the jl audio 12 w6v2d-4's, I would highly recommend those. It'll slam and sound great, if you need any help with pricing e-mail me at joshualittle1982@yahoo.com and I'll be sure to refer you to someone who can help you out. I know you want the best for your money. |
Bronze Member Username: JoshualittleColumbus, Ohio United states Post Number: 11 Registered: Dec-08 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6865. I would recommend 2 of these amps, a friend of mine can get them for around $400 a piece. And I would go for 4 of these subs.http://www.dealercostcaraudio.com/12w6v2.aspx. Please whatever you do don't go with the square's, I've heard them and while there loud, the sq sucks big hairy balls. If your interested in the amps at around $400 a piece email me at joshualittle1982@yahoo.com |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1969 Registered: May-07 | R.I.P. Ecoustics |
Gold Member Username: Snowball123West Allis, WI Post Number: 1868 Registered: Oct-07 | true that. there is some shi*ty advice in this thread. |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1980 Registered: May-07 | agreed, just about every post but the posts from the regulars.. as far as l7's nolt needing a bunch or upograds, well..... With 2 L7's on recomended power you would need upgrades... Even moreso with 4. |
