My Truck (Stock to Rock!)
Username: Senatorgleason
NJ USA
originally posted in the wrong forum
Hi guys, I just upgraded my 2001 Ford Ranger from stock Everything to a formidable system.
I started by adding an Alpine CDE-9881, because my main concern was compatibility with my iPod and the ability to read MP3 cds.
Then the itch kicked in for me to do the speakers, so I did some research and ask a few people who knew a lot about car audio and I ended up putting in 2 pairs of Infinity Kappa 682.7CF 6x8 speakers.
After that, It came down to a decision of how i wanted to go about putting a subwoofer in. Build a box or find something custom-fit? Well MTX did not disappoint me. I found a pre-fabricated, custom fit enclosure that fits 2 10" subs.
I bought an Infinity Reference 1300a 300-Watt amp to get the subs goin, and I was ready to install. I already had the HU put in at bestbuy (free installation since i bought it there), I did the speakers myself, and I took the sub/amp to bestbuy and let them do it. I can handle simple wiring, but the task of getting the sub running was out of my league.
The quality of sound in my truck has increased exponentially as a result of my upgrade and I'm starting to wonder why I waited so long to do it lol.
Now, after all that, I have a question. My truck can be heard (clearly) halfway across the parking lot of Six Flags Great Adventure. But IN the truck, the voice is distorted due to the subs. What do I need to do to make the vocals come in clearly at higher volumes?
Pics are coming soon.
NJ USA
Outside view of the truck, nothing special, cept my 8-ball gas cap decal woot!
http://i41.photobucket.com/albums/e256/senatorgleason/TruckFront.jpg
http://i41.photobucket.com/albums/e256/senatorgleason/TruckSide.jpg
Here's the HU, the remote for it, and BUDDY CHRIST!
http://i41.photobucket.com/albums/e256/senatorgleason/HUwithRemote.jpg
http://i41.photobucket.com/albums/e256/senatorgleason/HUwithBuddyChrist.jpg
http://i41.photobucket.com/albums/e256/senatorgleason/BuddyChrist.jpg
Here's the speakers, they're behind the grills but you can still seem them ok.
http://i41.photobucket.com/albums/e256/senatorgleason/SpeakerFront.jpg
http://i41.photobucket.com/albums/e256/senatorgleason/SpeakerRear.jpg
Here's the subwoofers running across the back. They fit so nicely under the jump seat. Good thing too because my friend had to sit back there on the way to Six Flags.
http://i41.photobucket.com/albums/e256/senatorgleason/Subwoofers.jpg
The amp fit nicely under the passenger side front seat.
http://i41.photobucket.com/albums/e256/senatorgleason/AmpRear.jpg
http://i41.photobucket.com/albums/e256/senatorgleason/AmpFront.jpg
After everything was up and running i put an Infinity and an MTX decal on the rear window.
http://i41.photobucket.com/albums/e256/senatorgleason/DecalInfinity.jpg
http://i41.photobucket.com/albums/e256/senatorgleason/DecalMTX.jpg
That's about it. Hope you enjoyed checking out my rude. Sorry for the messy carpet btw. The car wash and vacuuming is due next week lol.
Username: Thed42
Post Number: 106
hahahahah I love the plastic jesus. Have you heard Billy idol cover that?
NJ USA
I don't mind if it rains or freezes, as long as I got my plastic jesus riding on the dashboard of my car!
That's the first thing i started singing when i put him up there.
Btw. can anyone recommend a good car battery? I figure i'm gonna need a new one with the extra power drain from my stereo components.
Username: Kpa2727
Post Number: 549
kinetik or a optima yellowtop optima would prob work fine. i love infinity amps i got the 1600a.
Username: Jtown
ATX, Texas
Post Number: 585
you should turn that LP down a bit....
Username: B3n07
Louisville, Ky USA
Post Number: 482
yeah rock the infinity i love mines i have two of them hooked to two kicker 10 CVRS
Username: Unknownuser59
Yeah
Need to Register?
Forgot Password?
Enable HTML code in message
