Bronze Member Username: SaakethamPost Number: 37 Registered: Jul-05 | Folks, I wanted to see if I could create a diagrammatic representation of my current HTS, with photos of equipment, and also design a new one for my future home. Please let me know what needs to change and if you have any better ideas. I'm planning to set up the entertainment center flush against the living room wall and access the back from another room adjacent to the living room. That way, I gain lots of living room real estate, with an easier way to access the ports, controls, etc from the back. The room which will contain the back of the center will be cooled, of course. Current: http://www.bestindigital.com/Shalamar/CurrentHts.jpg Future: http://www.bestindigital.com/Shalamar/FutureHts.jpg Anil |
Bronze Member Username: SaakethamPost Number: 38 Registered: Jul-05 | Testing whether HTML is supported ... Current HTS <img> Future HTS <img> |
Bronze Member Username: SaakethamPost Number: 39 Registered: Jul-05 | Current HTS ![]() Future HTS ![]() |
wetewtn Unregistered guest | hey anil. how did you create those pictures? any particular software? do tell me thank you |
Bronze Member Username: SaakethamPost Number: 42 Registered: Jul-05 | I just used Microsoft Excel. I copied the photos of the components at home, from the Circuit City and other such websites and inserted them as pictures into the spreadsheet. The fern and the pottery stuff were from Pier 1 Imports' website. :=) Its an easy and cheap way of building a design and arranging and rearranging components, decor items, etc and then once I'm done, I can estimate the price of the items by checking their websites. |
Bronze Member Username: Em69OttawaCanada Post Number: 49 Registered: Mar-05 | I'm not sure if that top shelf would support the weight of your centre channel (and vases). |
Bronze Member Username: SaakethamPost Number: 43 Registered: Jul-05 | >> I'm not sure if that top shelf would support the weight of your centre channel (and vases). Hmmm, I hadn't thought about that. Thanks. |
Bronze Member Username: Mango_joeOrlando, Florida Usa Post Number: 37 Registered: Oct-05 | looks like rentacenter junk to me |
Bronze Member Username: SaakethamPost Number: 44 Registered: Jul-05 | >> looks like rentacenter junk to me You think so? If you have useful suggestions, I'll be glad to read them. :=) |
Bronze Member Username: Mango_joeOrlando, Florida Usa Post Number: 38 Registered: Oct-05 | buy somthing instead of dreaming and playing with your little pictures |
New member Username: TorebaYokohama, Kanagawa Japan Post Number: 1 Registered: Oct-05 | I disagree, build it yourself, that is the only way you get what you want. But some of the components look too low to touch/see. I guess if you are only using remotes, not a big deal but I like all my components a little higher off the floor (in case I do need to see/touch), perhaps a couple on each side just below the speakers. |
Bronze Member Username: SaakethamPost Number: 45 Registered: Jul-05 | >>buy somthing instead of dreaming and playing with your little pictures Thanks for the valuable suggestions. You should be a consultant. :=) BTW, the first pic (CurrentHTS), is what I have right now. But, it looks too cold to me, which is why I'm planning something with real wood. >>I disagree, build it yourself, that is the only way you get what you want. I'm hoping to do just that. The prices for such large entertainment centers are too high and unjustified, IMHO. A few visits to Lowe's and I could probably get the material. I have a friend who's good at carpentry and with his help, I could probably get it built. > but I like all my components a little higher off the floor (in case I do need to see/touch), perhaps a couple on each side just below the speakers. That's a good suggestion. I only placed all of them on 1 side so it will be easy to connect the cables to the HTS. |
Bronze Member Username: SaakethamPost Number: 46 Registered: Jul-05 | If anyone likes moving stuff around in Excel ![]() |
Bronze Member Username: SaakethamPost Number: 47 Registered: Jul-05 | Toreba, after following ur suggestions ... ![]() |
shamuchef's mommy Unregistered guest | Shamuch. Ok big man, you talk the talk so let's see your "awesome" setup that you must have. I mean, all I've see you do the last few days is go around bashing other people and their setups. Maybe your just bored and have nothing better to do? Maybe you should go outside, get a girlfriend, a life, anything. I think your mommy is calling you...God you're pathetic man. |
Bronze Member Username: Mango_joeOrlando, Florida Usa Post Number: 43 Registered: Oct-05 | your so funny i forgot to laugh at least i do not have a cartoon setup like this guy above |
ShamusDaddy Unregistered guest | Folks, ignore the idiot, please. He's probably sitting in some old dump with a TV he found in the trash and is depressed. |
New member Username: TorebaYokohama, Kanagawa Japan Post Number: 2 Registered: Oct-05 | I like it! That is the way I would go...probably want to use 3/4" wood. Not sure about the dimensions but also might want to consider a vertical brace or two up on the top shelf. now comes the hard part...building it! Good luck! |
Bronze Member Username: Javmo200Michigan Post Number: 58 Registered: Mar-05 | I just have one question --what are you doing for 1. Cable mamagement 2. Access to the components? I think is great to look at the design and pre-arrange things prior the real product is in. |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 31 Registered: Jun-06 | I think building your own entertainment stand is the way to go. Thats what i did and i saved so much money(i paid $0.00 for mine hehehehe) |
Bronze Member Username: WingmanaliveGreensburgh, PA US Post Number: 67 Registered: Jun-06 | Shamuchef. Leave this thread alone you retarded dwarf. |
Gold Member Username: IlluminatorUSA Post Number: 3442 Registered: Apr-05 | Paul, the majority of these posts were made almost a year ago... |
Bronze Member Username: WingmanaliveGreensburgh, PA US Post Number: 71 Registered: Jun-06 | Yeah I can see that now. There are way too many angry children on this forum throughout that if somebody doesn't stand up to them then the "valuable" participants will vanish. Be it 9 months ago or not, it just strikes a nerve now, when I read it. Chris lee is another one who needs to just keep his pie hole shut. He won't, cause the anger he stirs up is what excites him, like the other angry, childish, limp retards that lash out so quickly. I guess it's a form of "release" for them to verbally beat on people just like gangs beat up singled out individuals who are weaker then they, because they are the ones who feel pathetic and need an "outlet" for their anger. And hiding safely on the internet is too inviting to pass up. Sorry for the rants. |
Bronze Member Username: PolksavagePost Number: 61 Registered: Jun-06 | not too sure how good on a bass efeect your going to get keeping our sub in a cabinet like that |
Silver Member Username: StnorrisEldridge, IA US Post Number: 746 Registered: Apr-06 | i think it will look really good, i would just build it myself, if i were you, to keep the cost down. shamuchef, please STFU, and do everyone a favor. |
Silver Member Username: StnorrisEldridge, IA US Post Number: 747 Registered: Apr-06 | lol hahahahhaa. i didnt notice how old this thread actually was. i wonder if he ever ended up building it? hahaha. |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 34 Registered: Jun-06 | Wow me either lol. |
Bronze Member Username: CompumastaPost Number: 16 Registered: Apr-06 | I build custom cabinets for custom homes so i can do nothing but recommend doing it yourself. Your carpenter might have his own plans but i would recommend buying from a wood dealer, in las vegas(where i currently reside) i deal with austin woods as well as rugby wood. Believe it or not you will actually save some money and get what you really want. I dont know how much you want to put into it, or your decor, but mine i built is made of hickory and it is laquered clear...BEAUTIFUL. Oak or cherry look great as well, for lighter woods ash and maple are great woods. If you have any questions write me back. By the way, done correctly, no additional bracing will be necessary to hold the center channel(unless it weighs about 400 pounds. Me and my coworker have stood on what we build(which is 3/4" thick) without problems and im not the lightest person around at 250lbs or so. Real wood is the way to go though as it will last practically forever and will remain beautiful for years to come. Not anything like the pressed board in most buy and put in cabinets. Its hard to believe but it is actually cheaper than the pressed board too. |
Bronze Member Username: CompumastaPost Number: 17 Registered: Apr-06 | wow should have read the last two posts before i jumped the gun. lol |
New member Username: JadayPost Number: 9 Registered: Jul-06 | Yeah, I like your design and figuring out exactly what you want. My only suggestion is to consider moving the sub outside of the cabinet. With the powerful low frequencies, I don't want it to rattle off your vases or anything! It'll also transmit the bass easier if the sub is on the floor rather than up on the wood. |
New member Username: VangoreNew York, New York United States Post Number: 10 Registered: Jul-12 | Yes it does turn the amp on. A remote wire is hooked directly into the computer's powersupply. When the computer is turned on, the amp turns on |
Platinum Member Username: GlasswolfColumbia, South Carolina America Post Number: 14875 Registered: Dec-03 | AV rack http://i632.photobucket.com/albums/uu47/Glass_Wolf/Audio/DSCF7848_zpse1567d5f.jp g home theater in my living room http://i632.photobucket.com/albums/uu47/Glass_Wolf/Audio/005-2.jpg I'm planning to knock out the windows by the left main speaker and put the AV rack in-wall there, dry-walling around the cabinet, so the rack will be framed in there. stereo system in bedroom http://i632.photobucket.com/albums/uu47/Glass_Wolf/Audio/darkroom.jpg AV system component list: http://www.glasswolf.net/stuff/av/index.html |
Gold Member Username: Mrskullz1New York Post Number: 2115 Registered: Feb-07 | Wow i am so envious. What lighting do you have behind that TV/Speaker setup? Is it just a regular LED light kit? Also, can you slip me in your will somewhere lol Just that 66 Charger would be enough. |
Bronze Member Username: Abbaskhan8008Chiniot Pakistan Post Number: 35 Registered: Mar-25 | Looking for a trusted therapist infidelity counseling? At Baltimore Therapy Center, we make the process of getting help easy, respectful, and personalized. How to Get Started: Contact us through our website or call our office. Schedule an intake appointment with one of our skilled therapists.} |
