Logitech 5.1 Z-640 with Audiomax/AC'97
Username: Steyrtmp
I'm using an ABIT AN-8 motherboard with an AMD 3200 64-bit processor, and I can't get it to work right. The AN-8 comes with an Audiomax sound card, with Realtek AC'97 drivers. ABIT uses their own Audio EQ sound setup.
I have everything setup according to the manual, and have the colors matched, etc. I've tried switching front/back, and every other match you can think of.
I can get all 6 speakers to work; the front right and left work fine, but when the test sounds come, the left rear is replaced with the center channel, the right rear with the sub, the center speaker with the left rear, and the subwoofer with the right rear. Any ideas? I was running driver 372, but am going to try 376 and the new beta.
Thanks
Nate
SteyrTMP
Need to Register?
Forgot Password?
Enable HTML code in message
