Laptop to LCD Using S Video
Username: Atlantis_sweet
I have dell 600m and tried to connect it to my LCS using an S Video. I am not getting any signal.I have mobility radeon 9000 for my display settings. Can someone help me?
Any help in this regard will be highly appreciated. thanks in advance.
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 1588
Did you make sure and set everything correctly in the menu in properties?
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1367
go to ATI website ,get the latest "Catalyst Control Center" for your video card...then you can easy adjust your monitor(s) setting!
Username: Leew
Post Number: 1368
https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questi onID=21578
Username: Arande2
Post Number: 1592
Oh I thought he had that. Now that I read his post more clearly, I can see.
Jen, would you mind fixing your profile to have more info on your computer?
I switched to S video on my TV. It says searching for signals. When I try to extend my desktop and move on the right extreme corner it seems to dispalying the media files. I am not able to find the drivers for my Radeon 9000.
I dont know where i going wrong. thanks for the replies
I tried to update my driver. It says INF not found and could not complete my installation. Any suggestions as where I might be going wrong?
thanks
Username: Leew
Post Number: 1372
you no need driver for that! try to get "Catalyst Control Center"
Sorry I have Mobility radeon 9000 and i dont see any catalyst control center for the above set of dispaly control. Any suggestions to install
Username: Leew
Post Number: 1373
call to the dell customer centre! let them *** the head.But I am sure, they will re-address you to ATI...
Thanks for your inputs.
Username: Leew
Post Number: 1378
sorry,I tried my best! I am sure you have to adjust it from "Display Properties"
