Compaq wont start up
Username: Gvl121
I WAS WORKING ON MY LAPTOP UNTIL THE BATTERY RAN 0UT, I WENT HOME TO CHARGE IT AND NOW EVERYTIME I TURN IT ON, THE COMPAQ SREEN COMES UP AND THE NEXT SREEN JUST SAYS "CANNOT READ DISK PRESS CTRL+ALT+DEL TO RESTART" AND IT DOES THAT EVERY TIME. i WENT INTO SAFE MODE AND SETUP THE DEFUALT CONFIGURATION BUT IT DIDN'T HELP. WHAT COULD IT BE AND WHAT SHOULD I DO?
its a compaq presario 2100 if that helps
Username: Illuminator
Post Number: 3914
Maybe the hard drive went bad?
Just curious...why all caps? Upload
Username: Bigsim
Australia
Post Number: 163
Bad hard drive sounds likely. Jexx, maybe the caps-lock key is broken :-)
Username: Evadelparaiso
Puerto Rico
Post Number: 1700
Garret: reinstall windows.
Username: Elmagico
Post Number: 15
make sure you dont have a diskete in the floppy.
