Laptone with color lines in screen, HELP!!
Username: Cooldude69
Post Number: 47
Hi everyone,
I bought an emachine a year ago (which sucks), and it already is giving me issues.
Im getting these color vertical lines across the screen (to the right). When I apply pressure it goes away but when I release, it comes back.
It all started with one line and now there is ALOT!
PLEASE, IF YOU KNOW HOW TO FIX THIS OR MAYBE HELP ME OUT AND TELL ME WHAT IS CAUSING THIS
I would really appreciate your help!
Thanks.
Username: Seanpenn
Post Number: 12
Not much you can do to fix the problem, check if it still under warranty
Username: Project6
Post Number: 8536
Is it a CRT or a LCD screen?
Username: Nd4spd18
Post Number: 9
^^ If it is a laptop then the screen is an LCD. Duh. As sean penn said, there is not much you can do to fix it, you will need to replace the display. If you are good with electronics you can buy a new display and install it yourself, otherwise take it to a PC repair shop.
Username: Project6
Post Number: 8606
There is nothing on his post about a laptop.
Username: Illuminator
Post Number: 3408
The word 'duh' is funny because those that use it, use it to show stupidity, and in my mind, usage of the word 'duh' constitutes stupidity!
Anyway yeah, new LCD. Pop the laptop apart and get the part number off the LCD, google it, and order a new one. You're looking at 200-900 for a new LCD though 500 is the average. Check ebay if possible.
Post Number: 53
It looks something like this (LCD)
http://i2.tinypic.com/2059wzr.gif
For that I just save a little bit more money and buy myself a new one :\ Thanks anyways, to all of you for your help.
Post Number: 3438
Yep, needs a new LCD.
Username: Elmagico
Post Number: 16
nope its the cable what model emachine you m6000 or m 5000
