CD burn quality on a laptop
Username: Jamshed
Mumbai, Maharashtra India
Post Number: 19
I am planning to buy a laptop (undecided as to which one) and was wondering if there would be any audible difference in a cd burnt on a laptop and that which is burnt on a desktop?
I have heard that the sound quality deteriorates on a laptop. is this true?
Thanks in advance....
Username: Project6
Post Number: 9300
No...the deterioration is in the compression not the laptop vs desktop debacle.
Username: Jamshed
Post Number: 20
Thanks Berny...
By "compression" do you refer to the "compression" of an audio file to be burnt on the cd, as in the deterioration heard in an mp3?
Username: Project6
Post Number: 9317
Exactly. So, when you rip a CD make sure that you are using a lossless format.
Username: Basshead86
Google is your Friend, FL
Post Number: 4413
good advice. didn't know that.
i have a laptop and have burnt 100's of CD's and i have no quality issues.
Username: Project6
Post Number: 9584
Muddy,
What format are you using to burn the CDs? And where do you play them?
