Badge light for custom pc work
Username: Insearchofbass
Post Number: 3653
This company sells the kit for 11.95 but I posted it here because you could use their explanation to make your own badge light kit or any other spin off idea from this concept
http://www.crazypc.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=PC8490
Post Number: 3654
after look at the above listed web site they have some other intresting mod ideas so check out their site and come up with your own ideas if you like
Post Number: 3655
heres a website that explains leds
http://wolfstone.halloweenhost.com/TechBase/litled_LightEmittingDiodes.html
Post Number: 3656
the above website also has places to buy leds cheap and lists the technical specs of them
Username: Illuminator
Post Number: 2167
Even though that second website was primarily focused on Halloween lighting, I have to admit it had some excellent information regarding lighting for all applications...
Post Number: 3668
Glad you enjoyed it Jexx
Post Number: 2171
Yeah, you find some really good links...
Post Number: 3675
thanks for the compliment I get blessed and bless others with it
