D200
Keith Anderson
I currently use a D70 to shoot everything from nature to bands. I was wondering what the differences are between the D70 and D200 and if its worth the upgrade, Thanks
Keith Anderson
Username: Project6
Post Number: 4650
http://www.kenrockwell.com/nikon/d200.htm
Thanks, after reading that I'm sticking with the D70. Yea I could use the 5 frames per second every once in a while. But the 3 frames works just fine. And personally, shooting live bands where they move alot, I enjoy the 1/500 flash sync, I dont know how the 1/250 is, so I'm happy with what I have. Maybe in a little while I'll upgrade if I have, you know, like $1700 just laying around :-), which isnt gonna happen...thanks, Keith Anderson
