| I want to build my non rack mountable (normal)components into the wall with an open area behind it. Does anybody make a rack or something like that or does anyone have any suggestions? |
chad gundlach | I built a nice melamine wood rack on wheels that just rolls in an out of a space----used wood shelving from Home Depot with shelf holes already drilled then put black laminate on it----looks ok ---nice but cheap---i will be moving to a custom made rack soon-- |
Derek | Building your own would probably be the best way to create a custom rack or you could always call a Cedia certified installer. Also see. http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=14088186&St=6126&St2=-55154136&St3=54986648&DS_ID=3&Product_ID=117387&DID=7 http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=14088186&St=6126&St2=-55154136&St3=54986648&DS_ID=3&Product_ID=117399&DID=7 http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=14088186&St=6126&St2=-55154136&St3=54986648&DS_ID=3&Product_ID=6004&DID=7 Hope this helps. |
Anonymous | ur page is cool and all its just that i waz lookin 4 my aged type room not lilke a grandma house. im i think u need 2 add to yur pages 4 teenagers u know the colorful type things |
New member Username: HeffPost Number: 29 Registered: 12-2003 | AV Rak has a rotating audio/video rack solution--It rotates inside your cabinet or enclosure and mounts quickly with only eight screws. |
Silver Member Username: NencyPost Number: 197 Registered: May-09 | hello friend... Rack-mounted equipment as an option, but I doubt the idea would really take off... Thanks for.... |
New member Username: AvrakKelowna, B.C. Canada Post Number: 1 Registered: Nov-11 | Our company Avrak makes three models of 360 degree rotating AV racks, that fit into an entertainment unit, wall enclosure or ithey can stand alone. We also have various sizes as well as custom sizes for every model. You can check out our site http://www.avrak.com/ or email myself Ed Kriger at sales@avrak.com |
New member Username: Davidmartin123London, ABERDEENSHIRE United Kingdom Post Number: 4 Registered: May-14 | You must take help from a professional if you don't have idea to do it yourself. |
