How do I repaint Woodard iron furniture?
Username: Romney
CaliformiaUS
Post Number: 14
Anybody having any ideas for this...
Username: Project6
Post Number: 15939
I having ideas for morning wood when cats scratch yours.
Username: Nency
Post Number: 224
Hello,
Buy a paint made specifically for metal. Paint the metal furniture with a brush or spray with spray paint that will adhere to iron. Paint your furniture outdoors for adequate ventilation.
Username: Project6
Post Number: 15991
You think he should?
Username: Slevapaul
Ahmedabad, Gujarat INDIA
Yes you can paint the woodard iron furniture with the paint brush or the spray. They are the best ways to paint the furniture. Furniture is the important part in the house which adds more beauty to home.
Username: Claireloe
choosing the colour and tool for painting, sanding the furniture, start to paint. You'd better painting it at outdoor or you will get paint on your floor and other furniture. painting outside can also help the painting dry fast and keep the indoor air clean.
Need to Register?
Forgot Password?
Enable HTML code in message
