Need some advice
neuguy
hi all,
can anyone recommend a good cable for 5.1 setup? yamaha1400,sony dvd,sony vega and ascend cbm170 and the best method to connect it,thanks in advance
all the best,
neuguy
Username: Project6
Post Number: 3401
Try Acustic Research, you can get them at Best Buy and they are pretty well made.
For speakers get a good quality constructed 14 or 12 gauge speaker wire.
Do not spend too much money and time getting cables.
