Username: Goon Post Number: 277 Registered: Feb-05
Sunday, July 10, 2005 - 22:27 GMT i have two infinty perfects. the site says their nominal impedence is 4ohm, what would happen if i were to run them at 1 ohm? thanks for the help.
Username: Rds11 Louisville,
Kentucky
Post Number: 268 Registered: Nov-04
Sunday, July 10, 2005 - 22:31 GMT Well, first u better make sure ur amp is 1 ohm stable. then u better make sure u have everything wired up correctly to 1 ohm. all that the nominal impedance means is what the impedance of that woofer's voice coil. u will be fine.
Username: Tbolt Collipark,
GA
Post Number: 85 Registered: Dec-04
Sunday, July 10, 2005 - 22:32 GMT make sure your amp is 1ohm stable or else you'll fry it.
Username: Goon Post Number: 278 Registered: Feb-05
Sunday, July 10, 2005 - 22:35 GMT yep everythign is else is ok...thanks guys.
