Viewsat Platinum problem plz help!
Username: Asmith09
My viewsat platimum won't connect with my computer this has never happened before. I try to download the fix from Loader 2 and it stays at 0 percent. In the dialog box it says 0% and resending ZRQINIT.
Username: Mrgreg
Chatham, Ont. Canada
Post Number: 31
Make sure you have the right com port
Username: Asmith09
i've done all of that already i just re downloaded loader 2 and its the same prob.
Username: Mrgreg
Post Number: 32
Are loading from usb port or serial
Username: Asmith09
serial port
Username: Mrgreg
Post Number: 33
Do you have it set to com port 1
Username: Asmith09
Yes
Username: Mrgreg
Post Number: 35
Is your config set to auto or man. com port
Username: Asmith09
manual
Username: Mrgreg
Post Number: 36
Try it on auto com port 1
Username: Plymouth
Post Number: 4446
ZRQINIT is no commication with port
Uninstall the loader on computer, go in program file and delete the loader file, do a hard reboot, and install the loader from Viewsatusa.com, choose com port 1 in tool menu and try to load file in receiver.
Reply with result.
Username: Asmith09
Post Number: 7
just did same problem i'm really stumped
Username: Mrgreg
Post Number: 37
About time you showed up Plymouth
Username: Asmith09
Post Number: 8
Ok i reinstalled the loader and it was the same deal
Username: Plymouth
Post Number: 4449
Ashli
Try this loader from Viewsat
[link removed]
Username: Plymouth
Post Number: 4450
I will try Greg
Username: Mrgreg
Ont. Canada
Post Number: 39
Ashli I will leave this one with Plymouth as he is better at this then me. good luck
Username: Asmith09
Post Number: 9
Thanks for you helop greg!
and Plymouth i downloaded it and tryed the fix same problem as the loader 2
Username: Plymouth
Post Number: 4455
Do a scan with a antivirus and spyware, then retry.
Username: Asmith09
Post Number: 10
Yeah I'm way ahead of you i did that all earlier.. but i'm convinced its the box that's the problem
Username: Plymouth
Post Number: 4457
OK
Try it: Power off with rear switch, then press and hold the power button on front panel, power "on" rear button and release front button and download your file.
I am sure the problem come from your computer with ZRQINIT error message.
Username: Asmith09
Post Number: 11
ok i tried no lock though
i guess i will just have to get a new box
thanks alot for the help Plymouth i appreciate it!
Username: Plymouth
Post Number: 4462
ashli smith
Read it:
https://www.ecoustics.com/electronics/forum/home-video/519388.html
Sorry too many thing with nonsense happen, i try to found a solution.
