Mp3 help
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 521
i have a lg 8100 and it has a mp3 player. i bought a mini sd memory card so i can put songs on it to play through the mp3 player only thing is i cant figure out how to do it, can anyone help ?
Post Number: 525
bump
Username: Project6
Post Number: 4743
Find out the format your lg phone uses to play music.
Once you find out, convert the music files you want to the proper format. Copy those songs to the memory card by using a memory card reader. After you are done, insert the card into the phone and you are done.
Post Number: 533
mempry card reader ? where do i get that ?
Post Number: 537
bump
Post Number: 548
anyone?
Post Number: 552
bump
Post Number: 557
http://www.expansys-usa.com/product.asp?code=120071&partner=froogle
is this it ?
Post Number: 575
nvm found something else thx everybody lol
Username: Voltaickaven
how do you find the format of the fone?
Username: Kensongoo
Post Number: 11
Try borrow your friend's laptop. Usually laptop comes with card reader.
http://www.handcellphone.com
