Advice please
Username: Kiltylyn
DundeeScotland
Thank goodness there are sites like this that i can come and find some guidance. I have just purchased a proline portable dvd player a :
DVDP706W 7"
Can I make this one Region free does anyone know?
I bought it from
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZX J2aWV3&product_uid=105124
Thank you for your time
Linda
The region hack for the Proline DVDP706W.
1. Open disk slot
2. Type 81328
3. Press UP/DOWN until desired region. (9 for all)
4. Press Stop to store.
Region code hack posted by Iain, January 30 2006:
This applies to Proline DVDP706W (might also apply to DVDP705W).
1 - open DVD tray
2 - type 81328 on remote control
3 - Region is displayed on screen
4 - Press Enter/Select (button in middle of arrows on remote) to loop round the region codes. (9 is for all regions)
5 - close DVD tray
Username: Kiltylyn
DundeeScotland
Thank you so so much
Linda :-)
