Tychonic TY-MPX03
Chazz
I have the Tychonic TY-MPX03 and have copied the files but i cannot play it all I get is the little icons when I turn them on!
And plus i know they're their because on mu other PC it says that they are there!
Do you have the drivers for it? (The Tychronic)I'd like a copy of the 98 drivers.
thx Geoff
it shows dat the batteries on the tychronic is full. it won't play with the batteries n when i charge it
what should i do
what should i do
There seems to be a common problem with these players.
I've just been trying to fix one for my mate.
It wouldn't recognise or play any of the wma / mp3 files. Even though they were clearly visible when browsing as a removable disk in windows explorer.
I managed to get it going by Re-formatting as a removable drive (using windows 2000 Server) it wouldn't work properly on win2000pro, XP home, or XP Pro ! ! !
I'll try to upload a zip containing all the files on the OEM CD that we have.
I don't know if it's the same model etc......
Good Luck.
grrrrr blody mp3 players
