Unlocking
Username: Leomorales
I have a siemens m35i, motorola t2288 and sony ericsson t100, i would like to know if there is anything i can do to unlock it just by using the imei of the phone? without using any cable to connect to my pc, just by using phone codes, or free software that will calculate the unlock code of the phone. Thank you.
hi.i also have a m35i,i would b v gratful if u have any info yet,on how 2 unlock it!soz 4 the cheek,i cant find any info any where.just bout cables n stuff. cheers!
FreePhoneunlocking4u
http://www.freewebs.com/freephoneunlocking4u
Is it legal to unock your cell phone?
cor
yes
That depends, if you are the rightful owner with a phone that is not subject to contract or agreement by your/a service provider, then you can unlock your handset (depending which country you're in, laws change overseas) most P.A.Y.G HANDSETS ARE NOT SUBJECT TO ANY OWNERSHIP CONTRACT!
