Missing software for a RCA Lyra RD1020... HELP!
Username: Mrfast4ward
Purchased it about two years ago and now can't find the damn software... is there anyone that has this that could be so kind to get me a copy. I am willing to pay a reasonable amount for this.
Thank you in advance.
you dont need to pay me for this information because the original software can be downloaded from the RCA website itself. Try going to the following link:
http://www.rcaaudiovideo.com/Cultures/en-US/Downloads.html?ProductID=RD1020
It should have the updates and software to get your lyra working properly. I have the RD2780 and i was in the same position as you. so enjoy
Pastor Moses
pls help me with the software for thomson lyra pdp2820 i deleted all files on the hdd by mistake now i can play music with, the driver i cant find. somebody please help
Username: Freeringtones
http://www.techolio.com/rd2780_upgrade/
Here you can see a link to a program called H2Format try to use this, it worked for my RD2780
Or you can upgrade to the latest model, Rca Rd2850 Lyra or Rca Rd2850 Lyra Jukebox Mp3 Player
