S...l...o...w
Username: Kille
Post Number: 16
I just hooked up with high speed on my AMD, I'm running XP pro. The change from dial up is great, but. I have to wait forever for msn messenger to connect and most times it won't show my online contacts { number of } or the # of email at the top. There are other times when it will freeze up if asked to do more than one function. Any answers? Thanks
Username: The_image_dynamic
San Diego
Post Number: 2986
Sounds like you don't have enough RAM. XP Pro operates decently at 512 and great at a gig+. If you only have 256 (which is my guess) that is your problem right there.
