MAC Laptops?!?!?
Awesome A Productions
Can Apple Laptops play a standard American DVD?(Say the notebook had a dvd player.)
Username: Arrow224
Post Number: 28
Yes, provided you set the correct region.
Username: Cookco
if you should have any other questions about macs, you would be better off going to a mac forum. just go to www.applestore.com and click the support tab and then go to the forums.
