Hey Sean
Username: Araknid
BOCA , FL U.S.
Post Number: 699
I Have 2 comps, ones a crappy labtop That can go online, and the other has a burner but there some issues with it and it wont let me get online.
I want to know exactly how I can take stuff from this comp just mostly music, Then send it to the other computer through a dbl sided USB cable so that I can burn it.
And check out the post where you were talkin about E-mailin the guy about the sub.
Username: Araknid
BOCA , FL U.S.
Post Number: 730
Anybody know then?
Username: Insearchofbass
Post Number: 2812
you can use one of these
http://lpt.usbfireinfo.com/Products/HomeNetworkingAndLowCostICS/homenetworkingan dlowcostics.htm
or if you have etthernet cards in both pcs you can get a router they are pretty much just as cheap and you will be set if you get more than one pc up at a time with dsl or cable modem ...cable modem being the better choice
