Sony Cybershot DSC S40 won't turn on
Username: Cybfranc
HI
camera turn on few seconds and beeping before turn off.nothing works also zoom.nothing extern seems broken.no Reset button exist.no warranty.
someone knows the problem? I think the problem is zoom but can't confirm.May be the camera is dropped?.I'm not remember that.Anyway I want to fix it but don't where it is the problem.
thanks,and appreciate your help and suggestions.
Username: Jaydesai
I had the same problem today.Changed the batteries and it worked! I used the camera for about an hour and the batteries died so didnt consider it was the batteries. Try that you never know!?
