Help!! I bought a Vizio with no coax!
Username: Memo_nofear
I just bought a 50 inch vizio, got home all excited, so grab my cable to screw in to the Coax "f connector" and it wasnt there! It didnt come with it! I was wondering if theres anything I can do?? (besides using a VCR)
Username: Floyd_1977
Plainfield, IL USA
Post Number: 82
Why are you watching programming on a 50" TV via coax?
Are you using a cable/satellite box, or just
straight cable (from the wall, no cable box)?
from the wall..... well I live in South America so I have no other choice
Username: Hodedofome
TX USA
Post Number: 64
You can use something like this http://www.amazon.com/StarTech-RCACOAXMF-Type-Coaxial-Adapter/dp/B003K1V99C
Username: John_s
Columbus, Ohio US
Post Number: 1615
Willy, you have purchased an HDTV monitor. That means there is no tuner, so an "F" coax connector would be useless on this TV. Aaron's F female to RCA adaptor will not work either since that will only connect you to a composite input and you need a tuner to sort out the channels.
You need an external tuner of some sort and a VCR is the easiest and cheapest solution, unless the cable co. down there offers set top boxes which would also solve your problem (assuming that their STBs offer more than RF only outputs).
So if you haven't taken the TV back already use a VCR's tuner and let this experience be a lesson. Do your homework!
