Username: Spittin2rock Post Number: 118 Registered: Mar-04
Friday, September 16, 2005 - 05:49 GMT this really isn't an audio question but I have a 98 explorer and my door triggering device isn't working for the driver side. Is there a fuse or something I need to look at?
Username: Project6 Post Number: 5242 Registered: Dec-03
Sunday, February 05, 2006 - 16:30 GMT
Username: Pokerwhiz12 Post Number: 1 Registered: Mar-06
Monday, March 20, 2006 - 06:36 GMT yea check the fuses
Username: Pokerwhiz12 Post Number: 2 Registered: Mar-06
Monday, March 20, 2006 - 06:36 GMT or the wiring may have burnt out somewhere between the fuse and your door triggering device
Username: Pokerwhiz12 Post Number: 3 Registered: Mar-06
Monday, March 20, 2006 - 06:37 GMT if the fuses are all in order then try removing the side panels from your door and you should see all the wires
