.Cable Query
Username: Tryst1
Hi,
I am planning for good speaker cables for my home theatre.I intend to go for Van den hul skyline hybrid / snowline or any good quality cable from Monster.Iam a bit confused about choosing in between these.Please advice.
tryst1
wec
Neither, unless it makes you feel better to have expensive wire.
14/2 @ 20 to 35 cents a foot will be fine.
Username: Joe_c
Oakwood, Ga
Post Number: 650
If you want monster quality then yes go for the 14/2 power wire available at most hardware stores. If you have a setup that would benefit from more expensive high quality wire then try dh labs t-14 silver strand at $4 a foot, notable difference.
Username: Tryst1
How abot the QED interconnects, they have the whole range.
