Infinity 12"
Username: Unregisteredguest
Post Number: 7
Im wonderin if this amp http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10074473&catid=1 1031&logon=&langid=EN will be too much to run my Infinity reference 300W RMS 1200 max subwoofer. if its too much power would this one be sufficient enough to run it? http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000F S10059654&catid=
Username: Skies
Courtenay, British Colu... Canada
Post Number: 261
uhm... as far as i know, that sub is SCV 4 ohm, and both of those amps are overrated, and very poor quality...
Look into Phoenix Gold Xenon 400.1
Username: 420alldaylong
Post Number: 190
What ohm is your sub?
Post Number: 8
4 ohm
Post Number: 9
tyler
so what ur sayin is that even the 600W MTX wont be able to power it well? i dont need anything to great i just want it to hit those "lows" nice
Post Number: 192
That sub is not for bump it is for SQ.
Post Number: 10
what do you mean SQ is that for a ported box?
Post Number: 11
If so what kind of box wuld u suggest?
Post Number: 193
SQ means sound quality.
Post Number: 12
OK so do i need to tune a ported box for it? just explain to me what i need to do remember i dont want nething too loud i just want it to hit hard. and sound as good as i can get it without spendin too too much
Post Number: 195
Have you all ready got that sub? If not go with a different one.
Post Number: 13
Too late i already got it but i do have a 2 year warranty so i might be able to take it back to future shop n get a better one but what would you suggest
Post Number: 14
Oh yeah they'll only give me store credit so i have to use that at future shop i think it will be like close to 200 an im willing to put like 100-150 more into it
Post Number: 197
Do they sell kicker sub?
Post Number: 15
no the best they sell is MTX http://www.futureshop.ca/catalog/subclass.asp?logon=&langid=EN&catid=11051 look at them theres a link on the side of it for 12's and 10's
Post Number: 198
I would get the Rockford P212S4 12" 200 watts RMS Then go to SONICELECTRONIX.com and get the Kicker KX250.2 for $149.99 free shipping that will be perfect match.
