Loud!!!
Username: Snowblindace
Harrodsburg, Ky
Post Number: 13
I was wondering if the loud setting on my HU is not a good idea to use? i'm not using it but was thinking about it though i was just wondering if anyone could give me so advice on it.btw my head unit is a audiobahn A1150N.Thanks
Username: Lexuscoop
Phx, Arizona
Post Number: 1467
loud usually just hits the bass up so you can hear more bass, and like kicks the volume up a bit as well, you can use it, but you'll get more distortion when you to
Username: Rideredder
Cornell, IL USA
Post Number: 297
I use mine all the time. It makes everything sound alot better. I never get any distortion.
Username: Lexuscoop
Phx, Arizona
Post Number: 1470
ok, sorry, you have a higher chance of getting distortion when you use it and turn it up louder, if you know what i mean
Username: Illuminator
Post Number: 2964
Nice name, 'Der Fuhrer!' haha, I didn't know this board supported the omla (sp?).
As far as the loudness effect goes, check this out: http://sl.wus0.com/quclk.go?rd=http://www.bcae1.com/loudness.htm&res=6&crid=4cbf baae6e2ef51d&pos=1&mr=25&qu=loudness
Perry (creator of bcae1.com) claims that the loudness setting has "little or no effect" in the upper end of the volume range; I disagree. Like 'Der Fuhrer!' stated, it in fact does cause distortion at higher volume levels.
Username: Johammbass
Cork, Cork Ireland
Post Number: 10
"Loud" only puts more accent on lows and highs AND it takes affect ONLY at low volumes (on the HU) That was designed to sort of enjoy, hear more detail at lower volume,make it "juicier". When you crank it up >50% then the "Loud" does not take affect any more. With a high-end system "Loud" is not needed, but it may help an OK system at lower volumes.
Username: Thomas_g
NM
Post Number: 442
Use the loud button man!
Post Number: 2979
"When you crank it up >50% then the "Loud" does not take affect any more"
According to the graph on bcae1.com that isn't the case. In fact, it causes distortion...
Username: Moey
Sydney, NSW Australia
Post Number: 14
You get a much cleaner sound WITHOUT the loud button. It puts 2 much pressure on ur subs if u hav it on and turn it up. Many people blow their subs this way...
