Is there an easy way to store all my contacts to my phone rather than my sim card?
Username: Cronic06
I have the Motorolla V3 and just found out I cant put a specific ring or picture for a contact unless theyre saved to the phone. Problem is I have so many contacts and dont want to manually go to each one and switch it from SIM to phone.
Username: Redliner
Wilmington, Ma
Post Number: 892
ya go to your the contact and just edit them you should be able to switch them to the sim that way if you go to the store i am pretty sure they can do it for you in like 2 seconds
Username: Kensongoo
Go to http://www.handcellphone.com and browse miscellaneous devices. There is a device that can transfer/backup all your data
