Newbie
helllloooooo
Got a dish 500 twin Lnb what FTA reciever should i buy? that will work or in your opinion is the best for a newbie
Antuka
viewsat platinum
Username: H3lt3r_sk3lt3r
Post Number: 302
@helllloooooo
Any receiver would work with dish500.
But you should take a look at pansat 2700, viewsat platinum or c00lsat 4000 pro, all are easy to setup and use and have alot of support.
