I uploaded Wav files on Comp with WMA and cant convert them. Help
Username: Bradrgilman
GALvEStoN , Tx Usa
Post Number: 73
I uploaded some of my CD's and I think they were wav form and I could only upload them with Windows Media Player and now I cant format the songs to a MP3 format for my ipod and mp3 cd's. How do you upload cds without using windows media? I tried copying them and pasting them but I couldnt without using windows media player. I have 2 comp if you are wondering about the forms.
Thanks
Brad
Username: Project6
Post Number: 5402
The first problem is the program you are using, windows media player will always convert to WMA. However, Media Player can convert MP3s to WMA format. If you have an iPod just use iTunes to convert the music files to MP3.
Username: Sytrok
If you don't like that option there is a very simple program that you can use. The dbpoweramp music converter. I have been using this for years simply because of how diverse this utility is. It can be loaded and use most, if not all, known audio codecs.
Need to Register?
Forgot Password?
Enable HTML code in message
