Like
[Game][Free] Drag n Merge Numbers
Username: Goodamr
Post Number: 12
Drag n Merge is a new match 3 number game. Just Drag the bottom number to a number on the grid to be added or subtracted to match 3 or more same adjacent numbers horizontally and vertically, then they will be merged into the next higher number at their most far right-bottom tile.
Google Play Store: Drag n Merge Numbers
Amazon Appstore: Drag n Merge Numbers
You can place the number on the grid by 2 ways:
- Drag and drop it.
- Touch directly a number on the grid.
First, You have 5 cards. Every match gives you 1 new card. The value of each card is selected randomly from the list [+1, +2, -1, -2].
You will get bonus points when you match 3 or more different groups of numbers at the same time.
Simple rules:
- Every match gives 1 star & 1 new card.
- It costs 100 stars to remove a number from the grid using the Remove button.
- The game is over when you run out of cards and stars.
- It is your responsibility to save your progress to resume it later by hitting the Save button.
Every new level: minimum and maximum generated numbers are increased by 1.
Play, enjoy and have fun !
Username: Loraclip
Russia
Hi,
Few days ago I have downloaded lucky patcher from here. So, I want to know can I use this tool for modify this game?
Username: Georgeselwyn
This blog post is about game lovers. Drag n Merge is the name of the game. Drag n Merge seems to be an astonishing game. People should visit this site for more information. But also I can get best dissertation writing services to manage my daily tasks. Game lovers can avail this opportunity in these free days of quarantine. Thanks for sharing.
Need to Register?
Forgot Password?
Enable HTML code in message
Facebook
Shop Related Deals
Directory
