Car2004 radio code
Username: Aly01
hi i need radio code for my 2001 corsa c
it has philips car 2004
set type 03980
prod number FD 02 00 36 910078
thank you
Username: Regrooster
Post Number: 16163
post the other number beginning GM0400xxxxxxxx
Username: Aly01
unfortunately i can't read that number
Post Number: 16182
Is the number stamped in the metal casing ?
If not then it will have to be taken into a Radio Decoding Service to be decoded
It will not be free
Username: Le_canard
NorwichUnited Kingdom
Post Number: 1195
Hello,
If you need the code for this radio
Contact .... [ c.r.t.m.auto@gmail.com ]
Username: Le_canard
Post Number: 1197
Hello,
Username: Aly01
i found it now
it is GM0204Y1082347
Post Number: 16190
Sorry...this number GM0204Y1082347 is not in the available database
Try your Vauxhall dealer or take it into a Radio Decoding Service
