Grundig wkc 1650 vd
Username: Sunimex
can anyone help with the code of this radio Grundig wkc 1650 vd ------ GR0821R0136476
Username: Le_canard
Post Number: 73
suny
Username: Sunimex
Try here >>>> https://www.code-autoradio.com/
Username: Sunimex
Username: Regrooster
Post Number: 12469
suny
Username: Sunimex
Try code 1064
Post Number: 12470
Johnny
Username: Le_canard
You have already been told more than once that you should not be spam advertising your own decoding website on this forum when you know that the code can be calculated on here for free
Username: Sunimex
1064 does not happen
Username: Le_canard
Post Number: 75
suny
Username: Sunimex
Try here >>>> https://www.ivgsoft.com/radiocode.php?id=1828
Or <<<< https://www.code-autoradio.com/
Username: Sunimex
Post Number: 7
Post Number: 12477
OK ....then your code will be 0893
Username: Sunimex
Post Number: 8
0893 ===== it's not that.But thanks anyway.
Post Number: 12481
0893 is the correct code for GR0821R0136476
Check the Serial Number again
If it is correct then your radio may have been recoded in the past to a different number
Username: Sunimex
Post Number: 9
Thanks for your patience
Username: Sunimex
Post Number: 10
0893 is the correct code.After its introduction-----button U keep pressed
Username: Sunimex
Post Number: 11
