Phillips 212 Turntable part needed and where to find? Also, solder ?
Username: Blopes25
Hi,
Can anyone give me an idea where I might order a replacement push on/off button for a Phillips 212 turntable? If I can special order the part or similar after market switch on the internet is there an audio store in the Northern California region I might be able to contact for a replacement?
The wires were soldered onto the old switch. If I find a switch to replace the broken one what kind of soldering wire do I use to connect wire to switch? Many thanks.
Need to Register?
Forgot Password?
Enable HTML code in message
