Original Xbox wavy screen
Username: Gkermit7612
ok, i'm not very console savy and im ready to pull out my hair. my roommate is running his ps3 on a hdmi plug to his sound system. when i try to plug in my xbox I get wavy lines. people tell me to go to setting in my xbox and change things around but with a wavy screen i can't get there. the xbox has been reset so when i start it i know it goes to the time and date screen but dont know how to bypass it and get on with the settings..flying blind here...will appreciate all the help i can get
Username: Plymouth
Post Number: 15721
Marie
Welcome to eCoustics!
First try to set your XBox picture with the composite cable then try again until you get the picture!
Originally the XBox is set to 1080p, try 780p or 480!
Need to Register?
Forgot Password?
Enable HTML code in message
