xbox 360 help plz!!
Username: Spazplz
ok here it is when i turn on my xbox 360 i here the noise in the background going to the main page for the 360 but my tv screen says "unusable signal", i tried buying a new AV plugs but that did not work, so if anyone can help mr plz do.
Username: Bigsim
NSW Australia
Post Number: 289
Try changing the switch where the AV leads connect to the console, and see if that helps.
Username: Emerson1
Post Number: 14
On the AV cord where you plug it into the console there is a switch. One is for regular SD video and one is for component, make sure you have it set to the one that applies for you.
Username: Krina37
Hi
I've tried searching the forums but struggling to get the correct info. Please can someone help.
I have a pioneer 111d drive with firmware 1.23 and using clone cd to burn verbatim dvd+r dl disks but i am getting errors burning my xbox 360 backups. I believe i need to use a different firmware for the pioneer 111d drive but not sure which. Can anyone advised what the best solution is and how to do it?
Any advice would be much appriciated
______________________________
burn xbox 360 games ^_^ how to burn xbox 360 games
Username: Sauib
krinda 37 i have the same burner as you my burner just workes fine i didnt use no firmware on my burner what xbox 360 games are you burning cause the new games that just came out like moddern warfare 2 requres you to use an activation disk
Username: Sauib
Post Number: 7
xbox 360 best software to burn games go on this site http://abgx360download.com/
Username: Sauib
Post Number: 8
hey krinda 37 my bad well heres a firmware list for the pioneer 111d] http://www.cdrinfo.com/Sections/Firmware/SingleModel.aspx?DriveId=1300 well i hope that helps u}
Need to Register?
Forgot Password?
Enable HTML code in message
