I got banned from xbox live
Username: Birdwatcher
Post Number: 823
does anyone know any way around this problem, they wont let my console in
Username: Madashell
No way back with that console, once banned thats it!!!
You will have to get another console if you still want to use Xbox Live, & keep the banned one for playing backups on!
Username: Cejunkie
AZ
There is no way around this problem. You have to be careful with a modded system if you want to use Xbox live.
Username: Willwright
Can you just make a new account? Which games did you play online before they banned you??
Username: Project6
Post Number: 15972
What kind of mods did you make to get you banned? If it has anything to do with cheating...then yeah, you should be banned.
Username: Project6
Post Number: 15973
However, if you got banned because of a modded X-b0x, there are plenty of work arounds. Do a search on "banned Xbox Live".
I have a severe dislike for cheaters...
Need to Register?
Forgot Password?
Enable HTML code in message
