Can It Be Done! Hustling the 360...
Username: Tru_wpg25
WINNIPEG, MANITOBA CANADA
When I first bought my xbox,the first thing I did was load in a program where I could download games right to the new 120 gig harddrive.. SO now im wondering if It could be done to the xbox 360? The program I used for the xbox was Avalaunch.
Username: Cavsmaxima
New York United States
Post Number: 481
how did u burn games to it?
And is it possible to do to any xbox
Username: Dulledblade
Any Xbox? Yes, as long as you have a modded one. Also you can burn games for both systems (easily, search google), but once again your box has to be modded so it can read them.
But no program or modified dashboard has been made yet, so no direct downloading to the hard drive for the 360 yet.
Username: Greekgod690
Mississauga, Ontario Canada
no mods for 360 yet and i dont think there will be any soon
Username: Holt_champ
Htown, MI
Post Number: 427
how do you mod your xbox??
Username: Basshead86
FTW
Post Number: 9734
heard they have a patch online that enables you to save DVD's onto your HDD
Username: Tru_wpg25
Post Number: 7
thanx for the input guys but I heard that their wont be a mod for awhile...
Username: Extrmndor3
Sit and Look pretty
Post Number: 3463
go to mexico they will change your xbox 360 for a modded one with emulator in it and bunch of games and you will be able to back your own games my cosin told me all that they did its made a special firmware and updated the software and for the buynch of games they will have to sel you an extra usb harddrive. but keep in mind that if you mod that they will put like a firewall to make the operating system unupgradable from the firmware since they made a custom one but ull be able to upgrade the games like new maps or someting like that.
Sit and Look pretty
Post Number: 3467
http://www.xploder.net/products/148/Xploder-HDTV-Player.htm
Username: Mrshoehorn
You have to modify your firmware and do game burning.
http://www.xbox-scene.com
Need to Register?
Forgot Password?
Enable HTML code in message
