Hd xbox
Username: Sleepy6666
I was wondering if the hd cables for the original xbox make a difference in picure quality for halo or halo 2?
sweet_yus
Check this link it will tell you what xbox games are supported in HD mode
http://www.hdtvarcade.com/xboxlist.htm
Need to Register?
Forgot Password?
Enable HTML code in message
