Silver Member Username: DirtfarmerAlberta Canada Post Number: 685 Registered: May-04 | i think i got the wrong DDR ram for my compter ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,, :confused: i got this info from http://www.crucial.com Number of Slots: Slot 1 Slot 2 Slot 3 Each memory slot can hold DDR PC3200,DDR PC2700,DDR PC4000 with a maximum of 1GB per slot.* *Not to exceed manufacturer supported memory.Currently installed memory: 256 MB DDR PC2100 512 MB DDR PC2300 EMPTY Each memory slot can hold DDR PC3200,DDR PC2700,DDR PC4000 with a maximum of 1GB per slot.* *Not to exceed manufacturer supported memory. To see the memory installed in your computer click the Scan My System button below. Maximum Memory Capacity: 3072MB Currently Installed Memory: 768 MB Available Memory Slots: 1 Number of Banks: 3 Dual Channel Support: No CPU Manufacturer: AuthenticAMD CPU Family: AMD Duron Model 7, Stepping 0 CPU Speed: 1000 MHz Chipset: VIA Apollo KT266A Error Detection Support: ECC and non-ECC Supported DRAM Types: DDR SDRAM only Module Types Supported: Unbuffered and Registered Max Unbuffered DDR SDRAM: 3072MB Max Component Density: 512Mb 184-pin DIMM Banking: 3 (3 banks of 1) Max Registered DDR SDRAM: 3072MB Graphics Support: AGP 4X USB Support: 1.x Compliant ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,, i purchase on e bay 1GB PC3200 DDR400 PC 3200 PC2700 DDR 1 GB AMD RAM http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMEWN%3AIT& viewitem=%26item%3D300075453552%26%26 JEDEC Standard 184-pin Dual In-Line Memory Module 100% Backward compatible to PC2700 / PC2100 128x4 DDR Unbuffered 184Pin DIMM Performance: PC3200 DQ DQ Burst Frequency: 400MHz Inputs and outputs are SSTL-18 compatible SDRAM have 4 internal banks for concurrent operation Differential clock inputs Data is read or written on both clock edges Bi-directional data strobe with one clock cycle preamble and one-half clock post-amble Address and control signals are fully synchronous to positive clock edge Programmable Operation: Burst Type: Sequential or Interleave Burst Length: 4, 8 Operation: Burst Read and Write Auto Refresh (CBR) and Self Refresh Modes Automatic and controlled precharge commands Serial Presence Detect SDRAMs in FBGA Package RoHs compliance SPEED: PC3200 (Backwards Compatible with PC2700, PC2100 Enhanced for AMD Based Systems & Boards Details l 184-pin unbuffered DIMM l Density: HIGH l Maximum 6.4GB/s bandwidth l JEDEC standard 1.8 +/-0.1V power supply l 128x4 component configuration l CAS Latency 3 l 4 Bank l Off-chip driver (OCD) impedance adjustment, and on die termination (ODT) Product Name 1GB DDR400 400MHZ (PC3200) 184 Pin SDRAM MEMORY Technical Information Memory Size 1GB DDR 184Pin Number 1 x 1GB Memory Speed 400 Mhz More Information 1024MB x 1 High Density Chip configuration Non ECC Non Registered UnBuffered CAS LATECY CL3 PCB LAYER : 6 Layer Non Parity Physical Characteristics Form Factor 184-pin DDR Gold Pin Green PCB Warranty Life Time Manufacturer warranty -------------------------------------------------------------------------------- System Requirements : 1. Your system / Board must be able to use 1GB DDR modules 2. Not an Intel based or has ASUS board or nVidia Chipset on Board Compatible with ALL OTHER MAJOR boards and Systems with AMD Processors: These and more: Microstar Gigabyte Abit DFI ECS PCCHIPS EPOX Chaintech Biostar IBM Brand New Compatible Brand New Compatible Designed to specifically work with AMD based Motherboards ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; it all come down to high density and low density,, i should be use low, but i got high, some thing i did not know any thing about on til to nite |
Platinum Member Username: Project6Post Number: 12678 Registered: Dec-03 | Is this memory chip in place yet? What kind of computer are you using? |
Silver Member Username: DirtfarmerAlberta Canada Post Number: 686 Registered: May-04 | hey berny how it going no i have not got the ram yet- still on way to me-, i did everything right- but miss one small detail density, and that something i never notice before im useing a gigabyte GA-7vtxh+ MOBO --AMD Duron CPU Speed: 1000 MHz bleieve me i been do some reading of late when i came across this report http://www.overclock.net/faqs/113885-info-what-difference-between-low-density.ht ml What is the Difference Between Low Density and High Density RAM (A lot of users have fallen into attractive CHEAP PRICE trap by High Density module sellers and have complained that they are either VERY SLOW and/or will not run at all ) (A lot of users have fallen into attractive CHEAP PRICE trap by High Density module sellers and have complained that they are either VERY SLOW and/or will not run at all ) (eBay are plagued with High-Density 1GB modules at very low price, and you will be wasting your precious time and money having to return those high density 1GB modules to your seller for refund. So AVOID those 'High-Density) also came across this report all so http://www.kingston.com/tools/umg/default.asp Ultimate Memory Guide--- but and a big But im now wondering if i made a big erro in going cheap and with high density |
Platinum Member Username: Project6Post Number: 12686 Registered: Dec-03 | Doing good Arnie, thanks! Personally I don't know much about the high density stuff...but I'll put a word out for you and maybe they can give you a better answer. |
Silver Member Username: DirtfarmerAlberta Canada Post Number: 687 Registered: May-04 | ontil the other nite i never heard much about density either i allwas thought if you got the right ram,- it would work like for example, DDR pc2700, well i did that but found out some other thing as well DENSITY well i found a couple good site for othere to read hey is this how i started the last time with vcr etc lol he he |
Platinum Member Username: Project6Post Number: 12704 Registered: Dec-03 | Let me know if this thing worked for your PC. |
Silver Member Username: DirtfarmerAlberta Canada Post Number: 688 Registered: May-04 | well , i have found out low density ram is 100 % compatable with all system, while high density is compatible with maybe 10 % of system, and if you have a Intel, or nivida chip, do not even try, it will not work, as both co use a different set of chip---what we work is AMD or via chip, and even that there a possible that the computer will only see half of the ram i came across a couple link that say the high density ram it noting more then defect low density, but i have not seem to much info on that but i do know low density ram cost two time as much as high density *************** here's a couple of good links to check out in relation to ram http://www.techsupportforum.com/hardware-support/ram-power-supply-support/75262- high-density-memory-low-density-memory.html http://www.overclock.net/faqs/113885-info-what-difference-between-low-density.ht ml http://www.geekstogo.com/forum/index.php?showtopic=112556 http://forums.anandtech.com/messageview.cfm?catid=27&threadid=1999124 |
Platinum Member Username: Project6Post Number: 12948 Registered: Dec-03 | Arnie, How goes the memory install? I am curious. |
Silver Member Username: DirtfarmerAlberta Canada Post Number: 689 Registered: May-04 | berny well the got the ram and try it, it was suppose to be a 1GB of ram, but compter only see 512MB of it any one buying RAM DO NOT GET HIGHT DENSITY RAM- as most compter can not use it, and if ther cam will see only half of it my compter was suppose to be in the top 10 % that could use it, but did not i have AMD cpu and a gigabyte MOBO, well a lot of good that did me wish i would have know that ther was a diffent before i got it on e bay- now i find out hight density ram is all over e bay buter beware- and do not get hight density ram- you be sorry if you did |
Platinum Member Username: Project6Post Number: 12986 Registered: Dec-03 | I guess it just sounded so good with the words "high density" |
Silver Member Username: DirtfarmerAlberta Canada Post Number: 690 Registered: May-04 | low density ram,is the way, it use in all compter and is compatable, if high density can NOT be use in over 80 % of compter, why are ther make it |
