Looking for Pc keyboard...!!!
Username: Mess21
Hello friends,
I am bored of using keyboard with long wire. Now it's time for a change. I want to buy a wireless keyboard. It should be comfortable and easy to use, light weight, black in color(can consider any other color also). Please recommend me the best website where I can get the latest and advanced technology wireless keyboard.
Username: Candypants
you can just have a look at amazon.com.
Username: Insearchofbass
Post Number: 16751
i like the logitec wireless keyboards
Username: Appleiphones
United States
But i think that navtech is the best and cheap
Username: Kevinwhite
Post Number: 23
I have no idea with the wireless keyboard, but I think it is of great use to decrease the inconvenience.
Username: Project6
Post Number: 16010
How in the world is a wired keyboard an inconvenience? How far do you need to be away from your screen. Unless you are using it for a huge screen that you need to type at least 10 feet away...it would be inconvenient. Other than that, it is just a neat gadget to have.
Username: Rjs9163
Post Number: 22
Try amazon or ebay and go for purchasing logitech or microsoft wireless keyboard if is available
Username: Sofiasara
Post Number: 25
You can get various branded wireless keyboard form market. But before buying this you have to make some online research about some product. I think it gives you better result..
Username: Rsuman1991
Post Number: 7
logitech is best
Username: Rogerafrance
Visit Amazon.
Username: Bluudnobbut
You can search online and order from any of the sites like Amazon, Flipkart, etc.
Username: Amit2691
Hello Mess,
For daily purpose work, I recommend you to use you use an ergonomic keyboard that takes care of fingers pain, wrist, and shoulder pain from occurring. They also work on reducing the likelihood of conditions like Repetitive Strain Injury, or Carpal Tunnel Syndrome.
Here is some best ergonomic wireless keyboard you can buy:
1. MATIAS ERGO PRO
2. MICROSOFT ERGONOMIC SURFACE KEYBOARD
3. MOKO UNIVERSAL FOLDABLE KEYBOARD
Need to Register?
Forgot Password?
Enable HTML code in message
