Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1554 Registered: Jan-06 | Isnt there somewhere where i can find out what type of memory my computer uses...I'm thinking about adding another 512 |
Platinum Member Username: Project6Post Number: 12391 Registered: Dec-03 | What kind of PC do you have? |
New member Username: AdelaNew York, NY USA Post Number: 10 Registered: Apr-05 | Wolfman, if you haven't yet found out (you wrote back in Jan. 07) what exactly your computer has, use the FREE Belarc Advisor here: http://www.belarc.com/free_download.html Good luck! Adela |
Gold Member Username: DoreenakadjCanada Post Number: 5208 Registered: Dec-06 | I know this is an out dated thread, but it may come in hand for others. Windows XP NEEDS at least "512" to run properly.. the easiest way to find out is.... open up your tower and take out a ram stick , it will say on it what it is. But before doing this, please turn off the PC and for safety reason UNPLUG the power cord.... If you have all slots full .. and your not running a " celeron" you can upgrade the ram as high as 1 g more than that and XP can recognize it and you've wasted your money. |
