Can't Get Game to Start From ISO Image file
Username: Donshiv
Post Number: 35
Hi. I got this game and it's an ISO image file. I mounted the iso using "poweriso" and then I installed it. Now that I've installed it, and I click on the mounted iso file, I can't play the game. When I click on the mounted iso the game menu comes up, then I press play game and then it says check to see if cd is in the cd-rom drive. What am I doing wrong here? Please help. Thanks.
Using Vista by the way.
Username: Paulie0117
Cambridge, Ontario Canada
You need to download the crack for whatever game you have mounted. Just use the same torrent name of the game and add the word -crack- and download it, and place it in your game directory, assuming you have already unloaded the game. Your game directory will be in C/Programs/(your Games title) copy and paste the crack there and when it says there is already one there would you like to replace it just click YES
Username: Donshiv
Post Number: 36
Thanks, I'll try it.
Username: Th3pwn3r
Post Number:...
Post Number: 6850
You have to use a virtual drive to trick your computer that the disc is in the disc drive. Look for Daemon tools and you'll be set.
Need to Register?
Forgot Password?
Enable HTML code in message
