HELP stero speakers to pc
Username: K30wn
HELP, my stero speakers have no aux connection, is there any other way to hook them to my pc.
Username: P4s
no aux connection as in?
is it already hooked up to something else and you want it to be connect to ur PC?
Username: K30wn
there connected to my stero.
Username: P4s
Post Number: 10
okay. so i presume it is connected to your stereo system and you want your PC to be there at the same time
Username: K30wn
is der any way
Username: P4s
Post Number: 11
yeah. u'll prolly need a couple of splitters and also a Y-adapter
Username: Dscrobe
Reading, PA USA
Post Number: 83
Did you get fixed Ciaran?
Need to Register?
Forgot Password?
Enable HTML code in message
