Backup problem into Iomega Zip Disks...
Username: Adela
New York, NY USA
Post Number: 11
Hello, I'm trying to backup my "Documents and Settings" (3rd try) with Iomega zip disks 100MB. I have WinXP, OE6, IE6.
This time I was able to fill up the 1st AND 2nd disks. But on inserting the 3rd and last disk, a msg said:
"Current media is from a different media set." (I used the same type of zip disk...)
When I tried to open one of the filled up disks to see what it had backed up...I got this msg:
"The parameter is incorrect."
When I tried again, it said:
"You don't have access to the folder D. See your administrator for access to this folder. "
What do these msgs mean??? Anyone knows? Hope to hear from yu with some ideas? Thanks so much! Adela
