LCD monitor getting 'fuzzy'.
Username: Causarius
This Gateway LCD monitor (LE1936) has been getting progressively worse over the past few months.
Usually, it looks something like this: (scaled up)
And if I'm looking at white text in a colored area, it's like double vision.
The interesting thing is, it has come back to clarity two times. One, right now, has been perfect crystal clarity since I noticed it ten minutes ago. The other came back slightly, but a faint drop shadow/double image could be seen under closer examination--but still regressed back into being blurry, so I expect it go bad again, this time.
What in the world is going on?
Repair?
Username: Maxepotter
Display resolution different to monitor's native resolution. LCD monitors have a fixed number of pixels vertically and horizontally - this is its native resolution. If the current display mode is set to a lower resolution then there will be some interpolation going on. For the crispest display set the display resolution the same as the monitors resolution.
Username: Causarius
Thank you.
Username: Insearchofbass
Post Number: 16356
great help
Username: Aldomaletta
Cape town, Western Cape South Africa
Hi i have a problem with my laptop screen,when i put windows 7 theme as a wallpaper on my laptop, then my
screen gets a strange line in the top of it..but when i put one of the
others themes on, then the line don't show... can you please tell me what can be
the cause of the line showing on my screen.
Thanks
Need to Register?
Forgot Password?
Enable HTML code in message
