Software - Print Shop 12
Username: Waresgaragestereo
Fort Valley, GA United States
Post Number: 45
I have Print Shop 12. When i insert a headline and select a font, if i click to change the font again, it locks the whole program up. After i reinstall it, it works good for the first 2 or 3 times, then it starts again. it works good for everything else. the only problem it selecting the font for the headline. Could the files be corrupt? does anyone have any suggestions or ideas that i can try to tesolve the problem? The program's by Broderbund.
Need to Register?
Forgot Password?
Enable HTML code in message
